Can't install Fusion 360 - SSL Certificate verification failed
carlHDY6H
Message 1 of 25
carlHDY6H
Tried it numerous times on different networks. Turned off my virus scanning but still having problems.
[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self-signed certificate in certificate chain (_ssl:c:1000)
Attached is the error log.
Replies (24)
Message 2 of 25
RajkumarIlanchelian
@carlHDY6H Can you try the solutions called out in this article?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Precheck-SSL-Certi...
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 25
carlHDY6H
Took a look at that but I don't have the Fusion Service Utility installed and I can't find where/how to install that utility. I don't have any autodesk product installed.
Message 4 of 25
RajkumarIlanchelian
@carlHDY6H @Go to the add/remove programs and select Fusion and modify. This should launch the Fusion service utility.
Autodesk Fusion
Join Fusion Insider
Message 5 of 25
carlHDY6H
I'm on a Mac. All I have in the `Fusion Client Downloader.dmg` ¯\_(ツ)_/¯  This is the first time trying to install any autodesk product so I don't have any of it installed.
Message 6 of 25
RajkumarIlanchelian
@carlHDY6H @Took another look at the log files and it’s almost positive it is some sort of network error we are hitting here.
couple of things to try before using the article below.
1. restart your network to see if that helps.
2. on your Mach quickly create a new account and see if you can install successfully there.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Fusion-360-Failed-...
Autodesk Fusion
Join Fusion Insider
Message 7 of 25
carlHDY6H
I mentioned in my first post that I've tried on multiple networks with the same error. Just tried on a fresh user account on my Mac and get the same problem. localhost is properly set up in my /etc/hosts file.
Message 8 of 25
RajkumarIlanchelian
@carlHDY6H
2025-07-12 16:15:38,857 - MainProcess(3749) - InstallDriver - adsk.dls.streamer.network_checker - WARNING :: Failed to get client ip address [Errno 8] nodename nor servname provided, or not known.
This is the error reported in the logs that relates to this article - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Fusion-360-Failed-...
Have you tried this: (Skip 1 &2)
  1. Logout and Close Fusion
    2. Go to Launchpad - Uninstall Fusion
    3. Go to
  • Macintosh HD>Users>(username)>Library>Application Support>Autodesk>Autodesk Fusion 360>
  1. DELETE the following folders – Webdeploy, Web Services, Identity services, Autodesk Fusion 360 ((IF you do not have any other Autodesk products installed, delete the Full Autodesk folder)
  2. Delete the Fusion launch icon (from desktop or where you have it)
  3. Restart the Mac
  4. Download the installer again
  5. Now install Fusion
Autodesk Fusion
Join Fusion Insider
Message 9 of 25
carlHDY6H
Appreciate your help, but that didn't work either.
Message 10 of 25
RajkumarIlanchelian
@carlHDY6H
1.So those folders were present, you deleted them and redownloaded the installer and hone trying to install again you get the same error, right?
2. When you mentioned you tried various other networks, what are the other network options you tried?
3. Is there a change to connect the Mac to a LAN rather than wireless?
Autodesk Fusion
Join Fusion Insider
Message 11 of 25
carlHDY6H
1. So those folders were present, you deleted them and redownloaded the installer and hone trying to install again you get the same error, right?
Only the webdeploy subfolder was present, so I deleted the ~/Library/Application Support/Autodesk folder
2. I tried tethering to my phone and got the same problem.
3. I don't have a LAN connection on my Mac
Message 12 of 25
RajkumarIlanchelian
@carlHDY6H Interesting. We are missing something here coz for this error one of the above solutions have worked. Long shot, but do you have any other machine that you could install Fusion on using the same network?
Autodesk Fusion
Join Fusion Insider
Message 13 of 25
carlHDY6H
Odd. I don't have another machine unfortunately.
Message 14 of 25
RajkumarIlanchelian
@carlHDY6H I will consult with your engineering team but another long shot - are there any pending macOS updates?
Autodesk Fusion
Join Fusion Insider
Message 15 of 25
carlHDY6H
Nup, fully up to date here.
Message 16 of 25
RajkumarIlanchelian
@carlHDY6H Can you check the trust access for Autodesk entries on your machine based on this article?
https://support.apple.com/guide/keychain-access/change-the-trust-settings-of-a-certificate-kyca11871...
Autodesk Fusion
Join Fusion Insider
Message 17 of 25
carlHDY6H
There aren't any autodesk entries in my keychain
Message 18 of 25
RajkumarIlanchelian
@carlHDY6H
Go to Keychain access app - certificates - systems - is this where you do not see any Autodesk entries ?
Autodesk Fusion
Join Fusion Insider
Message 19 of 25
carlHDY6H
Correct. I did a search as well and there are none.
Message 20 of 25
rezakazemi
I am also having this issue and have followed the steps above, without success. I'm fairly frustrated right now and would appreciate some help on this as well.
