Can't Emboss total circumference of a cylinder, BUG?
HughesTooling
Consultant Consultant
HughesTooling
If I create a sketch the same width as the total circumference of a cylinder Emboss gives an error about overlaps. Seems like this should work.
Only workaround seems to be leave a gap then delete the surfaces but this seems like a bodge! See attached file.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
dsouzasujay
Hi @HughesTooling ,
Looks like a bug to me.
I will get back to you with more information, for now i have created an internal ticket FUS-82135.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
dsouzasujay
Hi @HughesTooling ,
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
