Can’t drawing from design after update.
shemalesu
Message 1 of 8
shemalesu
Dear all :
I can’t use drawing from design or from animation after update.
It shows red screen after the drawing plane open .
Does any one know what is the problem ?
sincerely !
Replies (7)
Message 2 of 8
jhackney1972
This problem is usually caused by your Graphic Driver.  Have you tried to switch to a different one?
John Hackney, Retired
Message 3 of 8
shemalesu
Any other way ? seems not working .
Message 4 of 8
shemalesu
still open a red screen .
Message 5 of 8
jhackney1972
Your screen capture is very odd.  You should have more graphic drivers than are sowing.  Look at my post, you will see others, especially DirectX drivers.  You need to follow this article and see if you can determine why your Windows DirectX drivers are not available.  Also I would update your video card graphic drivers.
Message 6 of 8
shemalesu
Here is my system .
only have one select.
There was all fine before I renew my Eduction account 4 days ago .
I can't use any other function If graphic driver have issue , is that right ?
Message 7 of 8
jhackney1972
I did not realize you were using an Apple product, I thought you were on a Windows based computer.  I have no experience on Apple products so I will have to defer to someone else that has the needed experience.  Good Luck.
Message 8 of 8
urban_harrysson
Hi, I had the same problem. The solution was to select the "Open GL Core Profile". This required a restart of Fusion. I have the same graphic card, but is running 14.4.1.
Kind Regards,
Urban
