Update failed with log:
2024-04-22 13:07:43,467 - MainProcess(43844) - Dummy-4 - adsk.dls.streamer.process.process - INFO :: The host autodesk.com is accessible
2024-04-22 13:07:43,467 - MainProcess(43844) - Dummy-4 - adsk.dls.streamer.process.process - INFO :: S_I: MjMuMjEuMTg5LjExMw==
2024-04-22 13:07:43,468 - MainProcess(43844) - Dummy-4 - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC41Ny4x
2024-04-22 13:07:43,658 - MainProcess(43844) - Dummy-4 - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOiAgZG5zLmdvb2dsZQ0sIEFkZHJlc3M6ICA4LjguOC44DQ==
2024-04-22 13:07:43,659 - MainProcess(43844) - Dummy-4 - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-04-22 13:07:43,659 - MainProcess(43844) - Dummy-4 - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "R:/Lib64/Release_Build/Core/Neutron/Server/Base/pylibtemp/adsk\dls\streamer\process\process.py", line 1185, in execute
File "R:/Lib64/Release_Build/Core/Neutron/Server/Base/pylibtemp/adsk\dls\streamer\process\process.py", line 1503, in execute_check
File "R:/Lib64/Release_Build/Core/Neutron/Server/Base/pylibtemp/adsk\dls\streamer\process\process.py", line 554, in _init_registry
File "R:/Lib64/Release_Build/Core/Neutron/Server/Base/pylibtemp/adsk\dls\streamer\configuration.py", line 452, in override_for_update
adsk.dls.streamer.exceptions.FailedStreamDetectionException: Failed to find deployment stream associated with the file ***/Local/Autodesk/webdeploy/production/3167d85f5fd4280287d8295f20592fa13b977617/
2024-04-22 13:07:43,659 - MainProcess(43844) - Dummy-4 - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-04-22 13:07:43,677 - MainProcess(43844) - Dummy-4 - adsk.dls.streamer.process.process - WARNING :: Exception in Update Failed to find deployment stream associated with the file ***/Local/Autodesk/webdeploy/production/3167d85f5fd4280287d8295f20592fa13b977617/
It's not clear how I could fix this.
