Bugs?
Bugs?
Bugs?
I have found since the last update I have a few thing not working as they used to on my Anilam 4200T controlled lathe with a 8 tool turret .
1. Coolant turns on and stays on during tool change. I previously modified this so it turned off , changed tools and came back on before continuing.
2. Looking into problem 1 in the post lead to problem 2. Posting with export cnc file to vs code fails at on section end for the last record , no matter how many operations are in the post.
Error: Autodesk HSM Post Processor extension not found.
Error at line: 100
Failed while processing onSectionEnd() for record 2751.
Error: Failed to invoke function 'onClose'.
Error: Failed to invoke 'onClose' in the post configuration.
Error: Failed to execute configuration.
Stop time: Wednesday, November 112020 10:54:52 PM
Post processing failed.
3. I previously posted about the new Turning profile roughing and finish not have a safe Z retract option when inside profiling is selected. I did find a post that suggested turning on legacy tool paths to get around this.
You can put the legacy profiling strategy back on the menu by doing the following:
Solution -> type cam.f in the text prompt, click enter
                    check the option "old-turning-profile-strategy", click close
Personally I still prefer the old strategies.
  • Bugs
seth.madore
I'm not seeing an Anilam lathe post in the HSM Post Library. Can you share it here, along with a sample file?
File > Export > Save to local folder. Take that .f3d file and your .cps post file and dump them into a .zip folder and share that here, if you don't mind
Seth Madore
Hello Seth.
   If I post a setup file with the Anilam post it works fine and is executed by may lathe just fine , only the coolant does not turn on and off with the tool change. If I post the same setup file or any setup file with the CNC to VS code post it will fail at the last onclose function in the file.
   I have modified my lathe and Anilam post heavily to suit. I have no problem fixing the coolant if I can debug it with the CNC to VS code.  Even though it  seems to be a  change Auto Desk has made that has jacked it up. I have not had time or inclination to look at the CNC to VS code post to see if I can find some thing wrong. I figured that should be Auto Desks thing as everyone will use it and it should be maintained to their standards.
  If the Anilam lathe post is no longer available I think I have an original copy if anyone needs it.
