Bug? Thin extrusion has different thicknesses for same profile
GRSnyder
GRSnyder
Here's the object from the attached file:
This a flat-washer shape with a single thin extrusion operation applied to it. The selected profile for the thin extrusion is one face of the "washer". As you can see in the image, the outside of the profile gets the requested 1mm thickness but the inside is double thickness.
Incidentally, it would be really nice to be able to select model edges as input for thin extrusions, for example, if one wanted only the inner or outer cuff for the object above. Does F360 have the concept of "edge chains that form valid profiles?"
jeff_strater
this looks like a bug.  It appears to work OK if you use a sketch, but is incorrect if you select this face (the preview is correct, though).  We'll investigate it.
Jeff Strater
Engineering Director
jeff_strater
just FYI: created bug FUS-106102 for this issue.  Thanks for reporting it.
Jeff Strater
samuel.templeUCPAE
There has now been a fix implemented for this bug, I have tested this in our development build and it is now working as expected. This will be going into the July Release.
Thank you very much @GRSnyder for letting us know about this bug. We really do appreciate your help and your patience.
Samuel Temple
Senior Software QA Engineer
([email protected])
Become an Autodesk Fusion Insider
As a Autodesk Fusion Insider, you will have early access to next official version of Autodesk Fusion, several weeks before it is released to the general public.
