Bad geometry when importing Solidworks from Onshape
kalmdown
kalmdown
I am moving a model from Onshape to Fusion 360 to use its CAM. I exported out of Onshape as Solidworks. When I import it into F360 I get bad geometry on the corner shown.
I imported the Onshape Solidworks export back into Onshape and it looks good - see below.
Onshape - Solidworks output reimported.Onshape - Solidworks output reimported.
I don't have any other CAD software to check or fix this. Any ideas how to get a good import into F360?
jhackney1972
Try exporting a neutral format such as SAT or STEP from Onshape instead of a Solidworks format.  I would try STEP first.
John Hackney, Retired
kalmdown
STEP had the same issue. STL imports but is all triangles. It can work but I'd really prefer if Solidworks or STEP imported properly. If I want to build off the object I want clean geometry so I prefer Autodesk fix their importers...
