Bug Report: Gear script crashed with divide by zero error
hex4def6
Observer Observer
hex4def6
Observer
Observer
Tools / add-ins / SpurGear
Try to type "0" in module field (in my example, I want to use 0.7 as module). Note error that appears:
Fusion 360
Failed:
Traceback (most recent call last):
  File "C:/Users/SS/AppData/Local/Autodesk/webdeploy/production/1f559bb8ae333199306b5c4f1fe680c6eb7ab9e0/Python/Samples/SpurGear/SpurGear.py", line 390, in notify
    diaPitch = 25.4 / result[1]
ZeroDivisionError: float division by zero
OK
hex4def6
Observer
Observer
OK, I seemed to have fixed the error checking with the following:
Line 385 onwards:
                if result[0and result[1] > 0:
                    diaPitch = result[1]
            elif _standard.selectedItem.name == 'Metric':
                result = getCommandInputValue(_module, '')
            if not diaPitch == None:
                if _numTeeth.value.isdigit():
                    numTeeth = int(_numTeeth.value)
                    pitchDia = numTeeth/diaPitch
and line 444 onwards:
               elif result[1] <= 0:
                    _errMessage.text = 'The diametral pitch must be greater than 0'
                    eventArgs.areInputsValid = False
                else:
                if result[0] == False:
                    return
                    _errMessage.text = 'The module must be greater than 0'
                    return
warnerjonn
Community Visitor
Community Visitor
The super class of ZeroDivisionError is ArithmeticError. This exception raised when the second argument of a division or modulo operation is zero. In Mathematics, when a number is divided by a zero, the result is an infinite number. It is impossible to write an Infinite number physically. Python interpreter throws “ZeroDivisionError” error if the result is infinite number. While implementing any program logic and there is division operation make sure always handle ArithmeticError or ZeroDivisionError so that program will not terminate.
try:
z = x / y
except ZeroDivisionError:
z = 0
Or check before you do the division:
if y == 0:
z = 0
else:
z = x / y
The latter can be reduced to:
z = 0 if y == 0 else (x / y)
