bug in revolve - possibly related to configurations
l_dowell1117
l_dowell1117
I have a body that is resulting in an error when attempting to use in an assembly. I have created a cylinder, through the side of that cylinder I have cut a small hole and in that hole inserted a grommet. The cylinder is configured to have multiple diameters. That grommet is a revolve centered in the hole cut for it and is configured to translate position for the change in diameter. In the base file everything results as intended. However, when this body is brought into another file to create an assembly of which it is a part the grommet revolves incorrectly. The side that should be parallel to the revolution axis is revolved in two pieces that don't match the sketch for the grommet. The first image is the desired result and is captured from the source file. The 2nd image shows how it revolves when pulled in to the target file. As created the grommet is a body of its own, but I also shrank the hole so that the grommet could be joined to the cylinder, no change. Don't know what else I can add
Lyle D
EvanGu
hi @l_dowell1117 could you share your configured design to me ([email protected]) so I can look into what the problem is? Either a shared link or a .f3z file would be fine.
Evan Gu
Inventor/Fusion QA Engineer
l_dowell1117
files sent
l_dowell1117
I'm confused but I'll survive. I tried several things yesterday with no success before posting this.  Today I reopened the trouble file and the problem was gone. I had not closed Fusion nor done anything different than what I had already tried. Unless this reappears I will consider it resolved
Lyle D
