Circle that cannot be deleted
scottycool
Observer Observer
scottycool
Observer
Observer
Hi. I'm trying to design some geometry here, and for some reason, as part of one of my sketches, there is suddenly this huge profile that I cannot delete. It doesn't seem to be defined BY anything, nor is it used TO define anything, but I cannot delete the actual profile.
jhackney1972
Attach your problem model to a reply Forum post.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
scottycool
Observer
Observer
here you go. Thanks in advance!
jhackney1972
Sketch 7 is the large circular profile that you are seeing.  In the animated GIF I show how to turn it off.  Model is attached.
By the way, I want to bring something to your attention. When responding to a post from someone, do not use the "Post Reply" icon as this will address your post to yourself. Instead use the "Reply" icon on the post you are responding to address your post to that person. Look back at the messages in this post and you will see what I mean.
davebYYPCU
You can get back to only the trapezoid articles,
Edit Sketch, window select all - Right Click and select, Move to Sketch Plane.
Most buggy profiles are removed, but not so sure it's still not going to be buggy.
Better to delete the sketch and start over.
2d sketches are recommended.
Might help....
@jhackney1972   - Eyeball - Really?
