I have a body that is resulting in an error when attempting to use in an assembly. I have created a cylinder, through the side of that cylinder I have cut a small hole and in that hole inserted a grommet. The cylinder is configured to have multiple diameters. That grommet is a revolve centered in the hole cut for it and is configured to translate position for the change in diameter. In the base file everything results as intended. However, when this body is brought into another file to create an assembly of which it is a part the grommet revolves incorrectly. The side that should be parallel to the revolution axis is revolved in two pieces that don't match the sketch for the grommet. The first image is the desired result and is captured from the source file. The 2nd image shows how it revolves when pulled in to the target file. As created the grommet is a body of its own, but I also shrank the hole so that the grommet could be joined to the cylinder, no change. Don't know what else I can add
Lyle D
