[BUG] grounding is deleted when reorganizing assembly
TrippyLighting
Consultant Consultant
TrippyLighting
I've got two simple components, a cube and a cylinder.
The cube is grounded and the cinder is joint to the top of it with a rigid joint.
then I create a new and empty component called Asm and rag the two other components into that assembly.
Fusion 360 deletes the grounding of the cube.
karina.harper
Autodesk Support
Autodesk Support
Logged as FUS-47954
rishabh.bisht
This bug was fixed in June 2019 release.
Please let me know if you can still reproduce it. Thanks!
Rishabh Bisht
Product Owner
TrippyLighting
This is fixed. Thanks!
