Bug for the parameters
mcappelaere
Message 1 of 9
mcappelaere
On this modeling https://www.youtube.com/watch?v=J6picYSItW8 , Manuel Warland encounters a memorization bug of the "LargeurSlot" parameter. He applies it on 5 Slots. When it changes the value of the parameter, it is not taken into account by the 5 Slots and the parameter must be re-assigned to them as a dimension. Many of us have reported this same bug on my Facebook Group while trying to reproduce the same modeling.
Replies (8)
Message 2 of 9
g-andresen
please share a sample file to take a look at.
File > export > save as f3d on local device  > attach it to the next post.
günther
Message 3 of 9
mcappelaere
I created a Slot with diameter = Parameter "try" (11 mm).
I create 4 other Slots with the same Parameter.
If I change "try" = 12 mm, we have mistakes.
Message 4 of 9
g-andresen
If existing points are used, the parameterization will not be applied during the first dimensioning. It will then work with a new dimensioning.
With free slots it works immediately.
günther
Message 5 of 9
mcappelaere
But you don't try to change the Parameter.
Message 6 of 9
g-andresen
In this situation, the problem is that some measures have not adopted the parameterization. This can be recognized by the missing suffix (fx.)
If after a new dimensioning with assignment of the parameter the P was taken over, this becomes clear by this suffix. Then also changes of the parameters have an effect.
günther
Message 7 of 9
JeromeBriot
@g-andresen, to me this is a bug. The width of the slot is not related to its length. The existing points only constraint the length of the slot. Did I miss something in your explanation?
Message 8 of 9
mcappelaere
@guenther.andresen, Yes for me there is a bug !!!
Message 9 of 9
g-andresen
In #4 and #6 I described that under certain conditions the assignment of the parameter is not done when creating the slot.
However, when re-dimensioning with the P, this is done.
I leave the decision as to whether this is a bug to e.g. @jeff_strater
günther
