BUG Can no longer enter Unicode in text.
HughesTooling
Consultant Consultant
Message 1 of 8
HughesTooling
@Phil.E  Noticed a while ago you can no longer use unicode in the text command in the design workspace, think it still works in drawings.
Here's an example from a few years ago showing it used to work.
Now if I enter \U+0101. %%c does still work for some special characters.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
Replies (7)
Message 2 of 8
Phil.E
Thanks for letting me know. To be honest, I have no idea what this would be used for. Can you explain a little how this is used?
Phil Eichmiller
Software Engineer
Quality Assurance
Message 3 of 8
HughesTooling
It's useful for entering special characters not on the keyboard. For me the recycle symbols are quite useful, I have these noted so I don't need to search for them.
Mark
Mark Hughes
Message 4 of 8
Phil.E
I see. Thanks for the explanation.
Logged as FUS-127235
Phil Eichmiller
Software Engineer
Quality Assurance
Message 5 of 8
jaywehner
Observer
Observer
Has this been resolved yet?
Message 6 of 8
josh.sapp
I find it faster to add the dia. and degree symbol using unicode then to go into the symbol menu when having to add them dimensioning drawings.
Message 7 of 8
HughesTooling
@josh.sapp You can use some of autocad's control codes for what you want. For example %%d for degrees, %%c for diameter and %%p for plus\minus.
Mark Hughes
Message 8 of 8
jaywehner
Observer
Observer
Unfortunately, I need to use other character codes. I have a workaround by just making the character in a vector program then importing an SVG. Just extra steps I didn't want to have to do.
