- Mute
- Permalink
- Report
Found a bug where the endpoints of an arc constrained to a projected arc's endpoint doesn't update after an edit.
Attached is a simplified example.
This is the original sketch.
After making the V cut out wider the endpoints of the arc have become unconnected
The endpoint are still constrained but the arc length does not update.
Just edit sketch2 in component1 and change from 10mm to 12mm
Edit. If you remove the centre constraint and drag the ends join up again.
Mark Hughes
Owner, Hughes Tooling
