BREP of STL Not Showing
SobtzakEngineeringTechnologies
Message 1 of 17
I'm new to using STL's.  I've watched several videos but still cannot figure this out.  I imported an STL file.  It had an issue of "No Volume" and per another post, I did a repair with the 'Wrap' option which took care of that.  The STL model is now a beige color.  I go back to the Solid Menu, right click on it, and I still do not have the option to BREP it to a solid.  My Design History is off so its not that.  Not sure what else I'm missing.  Here's a picture of what it looks like on my screen.
Replies (16)
Message 2 of 17
hamid.sh.
Firstly, the design is very simple; rather than trying to convert it I recommend just drawing it with Solid tools of Fusion 360 while using mesh only as reference.
That being said, if you share the STL here (zip it first) forum users might be able to help in conversion.
Hamid
Message 3 of 17
HughesTooling
The option's not in the solid workspace, it's in the mesh workspace. Also no need to turn history off, you never need to even in the past, that hack was just a lack of knowledge!
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 17
I found where to covert it to a solid BUT I'm still having some trouble.  I tried the prismatic conversion and it didn't like it.  I saw a video saying to Generate Face Groups.  I tried that but when I converted to a solid, it came out all messed up.  I've attached the STL file.  My WinZip is out of date so I just attached it.  Its only 92kB.  It has a few extra things in it that has to be deleted but its here.
I'm new to mesh and surfaces and still a novice with solids.  You mentioned that it would be easy to model.  I'm struggling on how to do this with the tapered neck going up at an angle.  Would you use a sweep with this or something?
Any help is greatly appreciated!!!!
Message 5 of 17
hamid.sh.
I had an incomplete BRep conversion (hence the yellow warning), but could fix it afterwards:
File is attached.
Edit: I must note the converted body has problems; I'd rather design it from scratch...
Hamid
Message 6 of 17
Thanks for the help  Hamid!  I really appreciate it!  I see you had issues with the sold model too so it wasn't just me!  If I were to redo this as a solid, what would be the best way?  Start with a drawing of the cross-section, extrude it, and then trim to get angles?  Or is there a way to use a sweep here?  Still getting my solid modeling feet under me!
Message 7 of 17
hamid.sh.
I am not at computer, but remember that side faces of the neck had a curvature so it seems to me it was made by Loft.
 But first you should consider the goal of this part. If the usage allows you can make a simpler version (e.g. by Extrude and then cutting side faces with an angle. this will make a flat face)
Hamid
Message 8 of 17
BardutIonut
Observer
Observer
Hi,and sorry for asking uninvited,but i have some problems whit a file ,i have the same yellow warning and i repaired it,but i can`t convert from MASH to SOLID,can you have a look Hamidsh please .
Message 9 of 17
HughesTooling
@hamid.sh.  I tried the conversion as well but there are some real odd anomalies in this part that don't add up. Would be nice to see the original solid.
If you look down from the top, the part with the hole through has parallel sides but the neck is tapered with no split between the 2 areas.
And the sides at the bottom also have odd faces that don't make much sense, the face groups in the image above are the beast I could come up with but don't convert well.
Stuff like this where the small fillets are don't make sense, the fillets are parallel but the face is tapered.
I've attached my file so you can inspect the face groupings I came up with. The sides at the base should really be parallel so the clamping screw has flat faces to sit on. This would simplify the model.
Mark
Mark Hughes
Message 10 of 17
HughesTooling
@BardutIonut  You are not going to have a lot of luck with this I'm afraid! Fillets just kill any chance of an easy conversion and fillets on curved face with more fillets just make it impossible.
This area for example is not going to convert. You might be able to create face groupes manually for all the fillets here but from my experience so far with conversions, for all but the most simple of parts it'll be quicker to model from scratch rather than waste time trying to convert (and failing).
Mark
Mark Hughes
Message 11 of 17
BardutIonut
Observer
Observer
Thx
Message 12 of 17
TrippyLighting
The issue isn't necessarily fillets in general, but fillets that blend into each other.
Message 13 of 17
Thanks for the info.  This is a part I'm going to CAM up and cut out of aluminum on my CNC so I need a basic solid model.  Per the feedback, I can do extrudes and then angle subtractions to get the design.
I am having one other issue.  I download the model files you all have posted but when I try to open them in Fusiion, I get a window that reads 'try again after update completes......you are in the process of installing an update that is required to open Untitled'    I've had this happen twice now.  I should have updates on.   Is there something I'm missing here?
Message 14 of 17
hamid.sh.
... I need a basic solid model.  Per the feedback, I can do extrudes and then angle subtractions to get the design...
Then in my opinion it's best you follow that route. I played a bit with the version @HughesTooling kindly provide but still could get a clean conversion.
... I get a window that reads 'try again after update completes......you are in the process of installing an update that is required to open Untitled'    I've had this happen twice now.  I should have updates on.   Is there something I'm missing here?
As far as I know this doesn't have anything to do with the files uploaded here. It's a common issue and clean reinstall helps; check here or search in forum.
Hamid
Message 15 of 17
Thanks Hamid!  I found out that my Fusion 360 wasn't updating.  It wasn't even showing available updates when I clicked on the clock.  So I followed Fusion 360's clean unistall and reinstaller.  That got me to the latest version and I was able to open your file.  I saved the solid you made vs. trying to re-draw and started to CAM it.
Wondering the best way to do this.  I first was just going to do a 2D Adaptive around the contour with the part laying on its side.  Then I was going to do a 2nd setup with the part at an angle to cut the slow, thinning the part up the neck portion.   I had trouble.  I could not get a 2D Contour to go around it though as a finish cut.  Not sure why.  I backed up and did a 3D Adaptive and thought I'd have the whole thing done.  It generated a toolpath but it looked pretty messy.  Anyone have any suggestions on the best way to attack this?  Below is a pic of the 3D Adaptive toolpath it made.  I've attached the file too.
Message 16 of 17
hamid.sh.
@SobtzakEngineeringTechnologies I thought you were going to remodel it and not use the converted one as we saw it has problems. Actually I regretted uploading that conversion so I just tried to remodel a simpler version for you. I suggest not going further with the converted model and use the recreated one. I don't know the purpose of this part so I relied on visual clue from the mesh and preferred numbers. Especially side faces are not similar to the mesh but you already mentioned a basic model is enough so I did it with a simple 2D cut of side faces. You should check if the final shape serves the goal of this part:
As for the CAM, I also see that in the converted model even though I can select the contour it won't generate toolpath (one more reason not to use the converted model...). But for the recreated part it works OK:
Hamid
Message 17 of 17
@Anonymous.sh - Yeah, I've now given up on the converted model.  I only tried to used it because I finally was able to open it but agree, it has issues from the original STL file.  This part is a shift lever for a motorcycle that my-coworker plays with as a hobby.
Thanks for attaching your model.  It helps me understand ways to attack odd shaped parts.  This really helped!  I'll re-Camming it now that it generates a toolpath.
Thanks!
