Problem with instalation
fusion.rez2
fusion.rez2
Community Visitor
Community Visitor
After problem with importing models and not recognizing remote disk, i tried to re-install but got error during.
[SSL:DECRYPTION_FAILED_OR_BAD_RECORD_MAC] (_ssl.c:2555)
Anyone got idea?
regards
mohammed.aliTDPXK
Hello @fusion.rez2 ,
I would first recommend you to please restart you machine and try installing again, if this does not work try the clean uninstall
Let me know if this works.Thanks!
Do like the post and Accept solution if this works for you
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
dooyoul_chung
@fusion.rez2
Similar case been resolved after cleanup %temp% folder and/or free up disk space.
Could you please try out below case accepted solution?
https://forums.autodesk.com/t5/installation-licensing/fusion-360-install-error-windows-10/m-p/109911...
Dooyoul.
