Bounding Box
Bounding Box
Bounding Box
Is there a way or app to calculate the minimum bounding box for several parts to put in a 3d sls printer with a minimum distance of 1.5 mm
automatic
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 Community!
Yep! So if you right click any components in the browser tree you can select Properties and bounding box will be one of the properties. However, since you want multiple bodies, this will be dependent on the hierarchy of your browser tree. For instance, if you want the bounding box of multiple bodies, they will all have to fall under one singular component.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
It is not the individual box but how to put them in to the smallest box(with a minimal distance of 1.5mm)  for printing,
