Body won't show
Body won't show
mikifox
Body won't show
mikifox
I am working on fixing up a design for Fusion 360 as it was imported from a dwg file. I've been labeling each part and adding appropriate joints. During this process, I've noticed that the 'add components from bodies' command actually turned my two pulleys into 6 separate components. While looking for a why to combine them into only two components, I noticed that one of the 6 pulley parts, Component60, actually refuses to show up. If I click on it in the browser, it will highlight and show a slightly visible outline of the body but nothing I do will actually make the body itself show up anymore. And playing around with the timeline does not bring it back either. Also, the eyeball is light up on both the body and the component so I have no clue how to fix this and compute all did not work.
g-andresen
that´s what I see:
günther
rishabh.bisht
I can see the body too.
Can you check if you changed the body opacity by any chance?
Rishabh Bisht
Product Owner
mikifox
Opacity was not doing anything for me, so, since both of you had no issues seeing it, I did something that I should have tried first. I closed and reopened the file. That seems to have fixed it.
