Best practices to create multiple versions of a design?
mlitzkow
mlitzkow
I have designed and built a coffee table using Fusion 360. I have done both a model and the CAM work for cutting out the pieces with a CNC router. Now I want to make similar end tables, a sofa table, etc. I want them to have all similar proportions and stylistic resemblence to the original coffee table. The coffee table is parameterized for length, width, and height which are the main things I want to vary. I would like to think there is some way to create a "collection" of CAD/CAM work for these table that makes use of the similarities and the parameterization already done. However, so far I have run into trouble trying to do it and am looking for some advice.
I thought "derive" would be the best route to go, but when I try that, the parameters in the derived model are frozen. I am reluctant to just copy the model in case I decide to make some change that should apply to the whole collection. I am open to a technique that results in multiple components in a single design, or multiple designs in a single project. I just want to set the parameters differently for each version. I will eventually need to set up the CAM work for the different variations as well. It would seem natural to use different parameters to control the variations in the models as well as the fixtures, stock, etc. that are required for the CAM work. What I want to avoid is having to set values of the servral parameters every time I want to work on or even view a specific version of the table. What is the best way to accomplish this in Fusion?
Thanks in advance,
Mike Litzkow
jeff_strater
What you need is called "configurations".  This project is currently under development, but is not yet ready for use.  If you sign up for the Fusion 360 Insider program, you can get early access to this in-development capability
Jeff Strater
Engineering Director
TrippyLighting
The feature set you are looking for is called Configurations in other CAD software packages. It is in the works and we might see first releases toward the end of this year.
In the meantime you will have to resort to more laborious workarounds. The Addin Sheeter might be of some use.
mlitzkow
Many thanks for your answer. I just watched a video on Sheeter, and it looks great. Will give it a try soon.
