Best Post Processor
Best Post Processor
jjurekUXLFE
Best Post Processor
jjurekUXLFE
Hi All,
I have a FoxAlien 4040XE and have been experimenting with different post processors and none seem to get the cut just right.
What is the best post processor to use with this machine?
-Jeff
seth.madore
What is the controller on your machine, and did they provide any sample programs that we could look at and make a recommendation?
What do you mean by "none seem to get the cut just right"?
Seth Madore
jjurekUXLFE
Hi Seth,
Thanks for getting back to me.
I don't know what the controller is other than the description here: https://www.foxalien.com/products/cnc-router-machine-4040-xe says "GrBL compatible"
By not cutting right (and this could be the machine itself)  X and Y seem to be off so I compensate for that.  But, when I do engraving, letters do not come out correctly (possibly design, but I have had other people take my design on a completely different machine and it comes out fine).  That is what let me to the post processor possibly being the issue.  I have used the plain GrBL post processor and have downloaded another from OpenBuilds.com called GrBL BlackBox.  Even with that one I have had to go in and edit the file  (It was placing a G54 and G53 codes at the beginning and end, the bit would just bury itself in to the table if these lines of code were present)
-J
seth.madore
Other than editing out the G54/55, did that post work properly? Do you have any photos of "didn't come out right"?
Seth Madore
