Behavior Of Non-Rigid Joints in Linked Components - Possible Support Request
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So I'm relatively new to Fusion 360, but the behavior of non-rigid joints in linked components seems to have some issues.
So for example, I have a slider joint in a design that is an assembly of components. This design is upward linked into a hierarchy of several other assemblies. I have set DRIVE, LOCK, REST values on the design that created the joint.
Here's what I see of the behavior...
1) You can independently drive, lock, unlock, set limits, set rest position on the joint at each level of the hierarchy (I think this is necessary and is allowed).
2) When you add or update a linked component, the DRIVE, LOCK, and REST positions in the linked component are not carried forward. You have to set them all up again at each next level (but see #4). I think it would make sense and be desirable if the add/update of the linked component carried the current settings from the linked component into the linking component (especially given #3). I think it would make sense if you still allow the joint to be LOCKED/UNLOCKED/DRIVEN/LIMITED after the add/update at any given level, but the initial setting should come from the linked component.
3) If you set the DRIVE and LOCK in a component that links a design with a non-rigid joint, the settings at this level go away if you update the component. This is probably necessary because the linked component update may have edited the joint to the point that these settings no longer make sense. However, this would make more sense if (2) worked the way I suggest.
4) If you create a Rigid Group in the design that created the joints, the joints become frozen and their positioning is carried up to the linking hierarchy on adds and updates. This is kind of a workaround for the behavior in (2), but it makes the joints rigid (un-drivable) which may or may be what is needed by the designer.
Assuming the above is correct, I would treat this as a support request for the modification described in (2) so that (4) is not needed to propagate joint settings from lower components.
