Broken Lines on Drawing
I am trying to generate a set of floor plans for a house.
First I created a separate  sketch for each room using only construction lines.
Then I created a new component called walls.
In the walls component I create a sketch called Renovation so I can generate a  model only containing specific rooms.
Now on the Renovation sketch I draw a rectangle over the top of the construction lines for one of the rooms.
So I now have  rectangles showing each wall for that room (four walls).
Using the surface tools I turn each rectangle into a patch generating a new body and then extrude each wall up by the required height.
I now have what looks like a bunch of solids representing the rooms.
So now go to Design and generate a drawing with a top down view
Make sure all of the construction sketches are not visible.  Make sure the bodies are visible.
Now on the drawing I have four solid walls BUT one and only one of the walls is shown with broken lines (the rest are solid).
As an experiment I create a rectangle which is not on top of any construction line and go through same process and it has broken lines as well
Any help appreciated.  thanks in advance
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post
günther
Thanks for prompt reply
Here is the file
I had a few more tries on this version with same result and I notice that even though I extruded the various surfaces it has not closed the top surface?
I left "as is"
OK I eventually worked it out.
Not knowing when to give up sometimes pays off.
The main issue was I had created a surface body not a solid body.  When I converted the surface bodies (which showed as broken lines on the drawing) into solid bodies the lines on the drawing were unbroken. Job Done.
