- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Just encountered a situation where Fusion 360 wouldn't let me pan/orbit/zoom my model, but I was still able to access the menus and other UI elements so I saved my work (going from v4 to v5, typed in a version description and clicked OK as usual), and then tried to close Fusion 360, which unfortunately froze as soon as I clicked the 'X' titlebar button. It wasn't the only program that would refuse to close and Windows wouldn't let me restart the system, so I forcibly shut down. It must have been a system-wide issue, maybe a disk IO error
Anyway, after booting back into Windows, I started Fusion 360 again, and discovered my project was still at version v4, not v5 as I expected. Fusion 360 didn't display the dialog to recover auto-saved data, even though I have my auto recovery save interval set to the default 5 minutes and I had been working on my design for about an hour. In the File menu I can see Recover Documsnts (0) meaning no documents are available for recovery. I've attached my logs to this message to provide further insight.
Based on this Autodesk Knowledge Network article, recovery files are created in the following directory:
C:\users\<username>\APPDATA\Autodesk\Autodesk Fusion 360\<GUID>\CrashRecovery
None of the .backup files present in that folder contained the latest changes I made to my design, which is kinda odd. However, I was able to recover my work from a .f3d file in a subdir of the following directory:
C:\Users\Manuel\AppData\Local\Autodesk\Autodesk Fusion 360\58H3R3DM8DXF\W.login
Unfortunately, the file from which I recovered my work didn't contain the design history, so when I opened it in Fusion I started at v1, although in this case it's not a problem as I was the only person working on this design.
I've just been doing a bit more testing to try to figure out how the whole file recovery thing works. Here are the things I understand (possibly incorrectly):
- Automatic recovery (Ctrl+S) and manual recovery (Shift+Ctrl+S) files are all saved to the CrashRecovery directory mentioned above.
- Automatic recovery (Ctrl+S) and manual recovery (Shift+Ctrl+S) files are functionally identical, the only difference being that the former are automatically created on a schedule, while the latter are created pre-emptively by the user.
- The above CrashRecovery directory contains a single recovery file for each design, which is overwritten with each recovery save operation.
- Automatic recovery saving only happens if there is something to be saved.
I would be grateful if someone could confirm the validity of the above points. If there is an official detailed documentation on auto-save and all those obscure folders, I'd be very interested if someone could share a link to it.
And here are the things I don't understand:
1.This forum message by James Youmatz says recovery save files are deleted upon manually saving the design or an intentional exit of Fusion (not a crash or force quit). Does this mean if I force quite Fusion 360 any auto saves will remain on my drive until I delete them manually?
2. I notice a number of .backup files in my CrashRecovery fodler corresponding to designs I've not touched for months, and which I know were definitely saved correctly (I can check on myhub.autodesk360.com), if what James says is correct, shouldn't these files have been deleted automatically?
3. There are two CrashRecovery folders on my hard drive:
C:\Users\Manuel\AppData\Roaming\Autodesk\Autodesk Fusion 360\CrashRecovery
C:\Users\Manuel\AppData\Autodesk\Autodesk Fusion 360\58H3R3DM8DXF\CrashRecovery
The first one is empty, while the second one contains the recovery files. What is the first folder for?
4. I'm not sure what Help menu > Clear user cache data intended to do. According to this message by Paul Clauss, this command clears the "local cache folder" which is:
C:\Users\<username>\AppData\Local\Autodesk\Autodesk Fusion 360\58H3R3DM8DXF\W.login
However, when I run this command nothing happens to that folder. Instead, it deletes the CrashRecovery folder mentioned earlier. The W.login folder contains a whole load of files referring to old projects. Is there an official way to flush that folder? Should I delete the files manually or are they better left alone?
5. My W.login directory contains the following sub-directories, all of which look pretty similar:
...\W.login\D
...\W.login\F
...\W.login\Q
I'm curious, what do the D, F and Q represent?
6. There are two CrashRecovery folders:
C:\Users\Manuel\AppData\Roaming\Autodesk\Autodesk Fusion 360\58H3R3DM8DXF\CrashRecovery
The first one is the one I mentioned earlier, containing the recovery files, but the second one is an empty folder, what is it for?
I could be over-analysing things but experienced data lost three times since I started using Fusion 360, so I want to have a good understanding of how and where data is saved, to prevent further problems down the line.
Your help is much appreciated!
