I have a part that I'm working on which is an anti-backlash nut for a 2040 aluminum extrusion. The part is attached here. I've created threads in this using the Coil functionality for an Acme lead screw which has an 8mm diameter and a 2mm pitch. As you can see from the design screenshot the threads slant towards the left. However, my leadscrew (image is shown here) has threads that slant towards the right. How do I reverse the threads in the design? I tried creating the coil from the far end than the backlash adjustment end but that didn't work.
