Auto-naming Nests and sheets
chrisCFHNJ
chrisCFHNJ
I see there is a way to auto-name nests. However, it doesn't look like we can add packaging to that, and that is probably because multiple packaging can be used for the same material and thickness. But could we have the sheets auto-named as well, and use the name of the packaging? We need to identify the specific sheet good that should be used for each sheet.
Here is my auto-name set up currently:
Here is what my current packaging setup looks like. the P# is the item# for each sheet type:
Let me know if there is currently a way we can do this.
Thank you,
-Chris
chrisCFHNJ
It also seems as if packaging names don't really save under each material type and thickness. It seems to remember sizes somehow, but not the names.
Is there some better way to do this?
chrisCFHNJ
Any help on this?
