fillet command
fillet command
rickir206
fillet command
rickir206
I have a model part that has two planes intersecting at a right angle.  I would like to add a fillet (like a fillet weld) at the line where the planes intersect.  When I attempt this, the "blue arrow" points into the line and the fillet appears as one plane "rolled under" the other.  My thought was that Fusion 360 does not recognize the two planes as part on one body and is just "rounding over" the edge of one plane.  I have re-drawn the object and get the same result.  Any suggestions?  Thanks.
g-andresen
Such fillets are only possible if it is one body, but not between 2 single bodies. The remedy is to combine the bodies.
günther
rickir206
Thanks, Guenter. Your suggestion worked.
