Arc lengths and centerlines
rhasell
Advisor Advisor
Message 1 of 28
rhasell
Hi
I have just installed and am trying to get my head around Fusion 360.
Simple things are getting the better of me (I am an Inventor user, so for me, Fusion is clunky and difficult, as I don't know how to do things yet)
I created a simple curved CHS beam and then tried to detail it.
I discovered that there is no way to add a centerline, or create an Arc length dimension.
Are these two options possible?
I am trying to educate myself a bit more, as there are times where I will need to use Fusion.
Thanks guys.
Reg
2026.3
Accepted solutions (4)
Replies (27)
Message 2 of 28
g-andresen
1. Please create separate threads for different questions.
2. Arc lenght (extended lenght) isn´t available yet.
Take a look at the Roadmap
günther
Message 3 of 28
jhackney1972
I would like to address your question about applying a centerline to a Fusion 360 drawing.  Fusion 360 can create a center mark for any drawing arc, but I will agree it is very small and cannot be expanded.  I would then like to propose a couple of work around choices for a centerline and the Arc Length dimension.  They are not direct clicks and picks but they get the job done.
John Hackney, Retired
Message 4 of 28
TheCADWhisperer
@jhackney1972
I did not see you address this issue in your video.
Message 5 of 28
jhackney1972
Truthfully, I did not notice what he point to as the centerline.  I assumed, bad practice, he was talking about the center mark of the arc which I mistakenly called a centerline. OOPS!
Message 6 of 28
jhackney1972
I apologize, I missed your request for the placing of a centerline along the arc length.  I was thinking center mark all along.  Anyway, my workaround for the centerline of the arc in the drawing environment is outlined in the attached Screencast.
Message 7 of 28
rhasell
@jhackney1972, thank you so much for all the help.
Yup, as I guessed, the arc centerline is a sketch work around, yours was better, than mine, I used the sweep sketch.
The arc length is a no go, having to manually measure and re-write a manual dimension is something that can go very wrong very quickly. The angle dimension on mine drawing had the dimension leaders into the arc center, so yours was better, and answered the question. As @g-andresen  pointed out, with the road map that arc length dimensions as well as centerlines are in development.
I will definately be doing a lot more testing and learning, I found that driven dimension in the modeling environment are not addressable, so they can not be used in formulas and calculations.
Reg
2026.3
Message 8 of 28
rohit.bapat
Hello all,
I wanted to give an update that, our team has been working on Arc length dimension. I won't be able to provide exact release date but as soon as validation is complete, it will be available.
Rohit Bapat
Sr. Product Owner
Message 9 of 28
DesignHJWZH
Still no curved centerlines?
Message 10 of 28
colinNJB25
The first google listing for "Fusion 360 curved centerlines" shows a idea station thread saying this is on the roadmap for 2016. I draw piping all the time and would love this feature.
Message 11 of 28
damiennn_w
I'm having the same issue, the part I've drawn is a tube rolled to a radius, and it has a split in the middle for a spigot when fabricated. Fusion will not dimension the left side, only the right side of the split, it drives me up the wall how the things that should be so simple are an absolute nightmare to do sometimes. I just can't find a way to get that outside arc dimension, as hard as I try.
Message 12 of 28
jhackney1972
Please post the MODEL, not the drawing, and indicate in a screen capture the dimension you want.
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
Message 13 of 28
damiennn_w
Thanks for your quick reply, I will upload it tomorrow after work if I don't figure out how to do it beforehand, but I have found a few things that should be simple but aren't, or should I say, can be done but it takes 3 times longer than it should and introduces the risk of mistakes, such as dimensioning a coped tube in the place that is most useable for fabrication, I'll  explain with the files tomorrow if you are able to help. Thanks again.
Message 14 of 28
damiennn_w
So I've just done an example of the tube I was trying to dimension just to make it easier to locate for you, for some reason the arc dimension doesn't seem to work on this part, and it is actually an important measurement when it comes to cutting and fabricating the part.
Message 15 of 28
jhackney1972
I have no idea why you created two bodies for the tube section but I combined them.  I created a drawing and then the required section view and added the Arc Dimensions.  The section view is required because Fusion cannot detect the curved outside radius to pull the dimension from.
Message 16 of 28
damiennn_w
The reason it is two bodies is that the part has to split, which also has to be shown in the finished drawing, inside that tube at the split point will be a smaller diameter tube inserted as a spigot. I find it strange that fusion can't just give the arc dimension of the right side of the split and then the left. Doesn't the split give it a point to measure too? I feel that the creators of this software would benefit greatly from the input of an actual fabricator when it comes to what dimensions would be preferable and worth spending time on. Don't get me wrong, I love the software, and I really do appreciate the help you give, I just sometimes find that things have to be done the long way around, Like this part for instance. To make it, both arc lengths are needed to cut the tube correctly.
Message 17 of 28
jhackney1972
You can dimension it with two sections also as you desire.
You can also give the centerline arc length.
Message 18 of 28
damiennn_w
Thank you, that is what I was looking for, how did you make a section view of the curve? And can you then delete the section view but keep the dimensions?
Message 19 of 28
jhackney1972
I simply created a section view using the top view in the normal way, hover over the ends and follow the green dotted line.  You CANNOT remove the section view as it is supporting the dimensions.
Message 20 of 28
damiennn_w
Ok I'll give it a try, Thank you again for your help!
