Help setting up Laguna IQ HHC in Fusion360 Machine Library
I have my Laguna setup well on the shop computer with Vcarve. However, I have a macbook and would like to have the flexibility to work on designs and toolpaths on the go.. I am using the personal version, so maybe that is the issue. Right now I cannot add the Laguna CPS file to my machine library. I have the CPS file save in my downloads, but it does not show up when I attempt to import the file to my machine list.
Any help or guidance here is appreciated.. only a week into CNC/design work. Looking forward to learning more!
serge.quiblier
Hello @Anonymous
You will need to copy your post in a personnal folder inside the Fusion 360 library for post processor.
1 - Open the post library.
2 - Select a personnal folder, on the cloud, or local to the computer.
3 - Use the import button to move the cps file from your download folder, into Fusion library.
Enjoy our product.
Have a pleasant day.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
jeffJANZD
Community Visitor
Community Visitor
Hi I'm having the same issues, but the response by @Anonymous shows a process not available in my system.  How do I load the laguna cnc configuration file into my Fusion 360 running on my Mac?
tpb_61
Observer
Observer
just found this post and went through what you suggest and the laguna.cps file imports fine. But when I go to setup a machine there is no option in the Machine Library to select the laguna machine, it doesn't show in the Machine library. What should I do
serge.quiblier
Hi All,
I think my explanations need to be clarified, as I may have miss-interpreted the request.
In order to drive a machine in Fusion several elements may be needed.
To generate the g-code a post processor is mandatory. (it’s a file with a .cps extension)
Then if the machine is a multi-axes machine (milling with more than 3 axis) then a kinematic definition must be provided. The machine definition is a .mch file if there is only the kinematic chain definition, and it’s a f3d (or f3dz) file when containing a 3d machine simulation.
Posts are stored in the post library, and the mch are stored in the machine library. F3d must be moved into a personal folder on the cloud or locally, then imported into the library.
In older posts, before the global restructuring we have done last year, the kinematic definition was previously handled in different ways.
Using post properties to select an existing kinematic (smoothie.cps using "Fourth axis mounted along" property),
Using a hardcoded kinematic inside a machine specific post (deprecated post dmg mori dmu 60.cps)....
Nowadays we prefer to use a machine definition file, stored in the machine library. This machine definition file may or not contain a solid model for 3D simulation. The 3d model can be identified by the isometric cube icon.
So, when importing a post in the post library, it's only importing the post.
If the machine is more than 3 axes, then a machine definition file may be used or created to define the kinematic chain. We are only providing machine definition for manufacturers who signed an agreement with Autodesk.
We do not use the 3d models, without their consents, because of intellectual property restriction.
We have not signed approval with all manufacturers.
We plan to later add some machine definition files without cad model, defining only the kinematics, using the information’s collected previously for another software. But the data need to be converted between the formats.
So, Autodesk have not created, as of now, any machine definition for the Laguna brand. If you need a machine definition for a multi axis machine, you can take a look at:
https://help.autodesk.com/view/fusion360/ENU/?guid=MFG-MACHINES
to learn more about it.
To recap, a machine is not absolutely needed for milling in 3 axes but is absolutely needed with the most recent post for multiaxis machine. It can support machine simulation, but it's not a requirement, only the kinematic definition is critical.
When creating a NC program, a post MUST be selected, and a machine definition MIGHT be required if the toolpath is multi axes.
If the machine had been associated into the setup, it will automatically selected when creating the NC program.
Let's hope it will bring more clarity.
Regards
Serge.Q
cam.autodesk.com
tpb_61
Observer
Observer
Thanks for the update, appreciate your help...👍
