Another Stuck upload issue
riaan.marx
Message 1 of 37
riaan.marx
Since yesterday my Fusion 360 refuses to upload files.
It just spins and spins forever:
and the job status window also does not progress any further:
and when I try to open the design from the project in the Data tab, there is an exclamation mark
and a message "the file is not available at the moment" for existing files. New files like the savetest I did above does not show at all, not even when viewing the projects on the web through a browser.
I have tried many of the solutions on the web:
Clearing cache
Manually clearing the queue
Created new project and new minimal design and tried to save
I even tried to repair, and ultimately uninstalled, deleted residual files and reinstalled Fusion 360.
I tried to collect diagnostic logs using the Help (?) button, but that produced this error:
Any help will be appreciated.
Kind regards,
Riaan
Replies (36)
Message 21 of 37
RajkumarIlanchelian
@riaan.marx Thank you for the logs. It certainly helped to understand what are some of the problems going on.
1. Please signout of Fusion/ Close Fusion / launch and sign in again
2. Test the save workflow now
We made a small change to the backend that this should now work for you. The certificate error that you are receiving is from the logs either from your network or from your proxy. Do you have a proxy set on your machine? it could be related that the proxy or this network is adding to the Fusion stuck issues.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 22 of 37
riaan.marx
Apologies - I have been occupied with other issues.
I will get back to you regarding the save issue, but on the proxy I don't have a proxy server. I connect to the internet using a 4G mobile connection. And I am not seeing SSL certificate issues on any other sites. But I let me test and see if the save issue is resolved at least.
Message 23 of 37
riaan.marx
@RajkumarIlanchelian, I have saved a few different projects and it seems to be behaving.
Thank you very much for whatever change was implemented.
Kind regards,
Riaan
Message 24 of 37
regRS43S
I have exactly the same problem. There are 17 jobs in the queue. Logout, login and clean cache doesnt help.
Message 25 of 37
RajkumarIlanchelian
@regRS43S Let me contact our engineering team about this.
Autodesk Fusion
Join Fusion Insider
Message 26 of 37
RajkumarIlanchelian
@regRS43S Can you please do a couple of things for us?
1. Go to Help - Support and diagnostics - Get diagnostic log files
2. This will generate a zip . Can you please attach the zip files here?
Also, we have made one small change in the backend for your account. Can you please restart Fusion 360 and see if there are no more files stuck in the upload queue?
Autodesk Fusion
Join Fusion Insider
Message 27 of 37
RajkumarIlanchelian
Autodesk Fusion
Join Fusion Insider
Message 28 of 37
regRS43S
@RajkumarIlanchelian Unfortunatly 19 jobs are still stuck in the queue.
Message 29 of 37
RajkumarIlanchelian
@regRS43S Thanks for the log files. After taking a look at this some questions and some suggestions.
1. It appears that 2 files that are stuck are causing a lot of these problems. *2023.* are the files involved. Are you making copies for a master design file in this case and they are getting stuck?
Suggestions:
1. Close Fusion 360
2. Go to %LOCALAPPDATA%\Autodesk\Autodesk Fusion 360\UNIQUE ID\P.login\DELETE jobs.json
3. Go to %LOCALAPPDATA%\Autodesk\Autodesk Fusion 360\UNIQUE ID\W.login\DELETE folder Q
4. Go to %LOCALAPPDATA%\Autodesk\Autodesk Fusion 360\UNIQUE ID\W.login\DELETE UploadQueuedFileList.xml
5. Now start Fusion 360
is the queue clear? If it is create a simple model and save it. Does it get stuck or gets uploaded?
Autodesk Fusion
Join Fusion Insider
Message 30 of 37
regRS43S
@RajkumarIlanchelian Your suggestion partially helps. The queue is empty now and a simple new design doesn't stuck. But any changes on the design I working on(Obdet2023) still can not be uploaded. The rollback to the last known version or saving this as a new design also doesn't work.
Message 31 of 37
RajkumarIlanchelian
@regRS43S Would it be possible to share this design with me? You can share the link here with a password protected and send the password to me in a DM or you can email me at [email protected] as well.
Autodesk Fusion
Join Fusion Insider
Message 32 of 37
haul12
Hi, I'm having the same issue. I've tried many solutions, nothing seems to help. Here is my diagnostics file.
Message 33 of 37
victoralessio508
Community Visitor
Community Visitor
Hello, I am also having the same problem! My files get stuck on the "cannot close until jobs in progress complete fusion 360" screen. There are already 23 files stucked. I tried restarting the login, reinstalling the program and several other things and the error still persists. What can you do for me?
Here are my log files 🙂
Message 34 of 37
pierre-yves.monarque
Hi
@victoralessio508 @haul12 @regRS43S @riaan.marx
Are any of you still facing stuck upload issues ?
Pierre-Yves Monarque
Autodesk Fusion 360 Team
Message 35 of 37
riaan.marx
I have not had any stuck uploads since, no.
Thanks Pierre-yves
Message 36 of 37
p.a.barends
Observer
Observer
After 12.00 european time fusion delayed the upload of files indefinitely stating that it tried to upload files from e.g. 10.00 am. I changed the time from 24 hrs system to the American AM/PM system and the problem was solved.
Message 37 of 37
frank_rodriguesRB32T
Community Visitor
Community Visitor
Yes the problem started yesterday when I uploaded a very simple design.
