The joint command and working with assembly is excellent in Fusion 360. Best Idea ever . But what I think is there should be advanced joints function , means like what If I want to drive a belt over 2 pulleys or a chain over a sprocket or a cam over cam shaft , means there is a function like enable contact , but working with it is little difficult . Some advance joint should be there or some solution is to be found . And there are alots of complicated examples but every problem cannot be solved using contact sets .
Sanket Patil
Mechanical Engineering
Expert Elite
Expert Elite
