Advance Joints
Advance Joints
sanket223.patil
Advance Joints
sanket223.patil
The joint command and working with assembly is excellent in Fusion 360. Best Idea ever . But what I think is there should be advanced joints function , means like what If I want to drive a  belt over 2 pulleys or a chain over a sprocket or a cam over cam shaft , means there is a function like enable contact , but working with it is little difficult . Some advance joint should be there or some solution is to be found . And there are alots of complicated examples but every problem cannot be solved using contact sets .
Sanket Patil
Mechanical Engineering
Expert Elite
jeff_strater
@sanket223.patil, there are a couple of IdeaStation items for these, I would encourage you and others who are interested to vote for them:
I would caution, though, that these are big projects, so, no promises on when these might be implemented.
Jeff Strater
Engineering Director
sanket223.patil
Yes , Good Idea .
Sanket Patil
Expert Elite
