I want to create a puzzle using this image:
To do this I'm extruding all the black sections out by 10mm and then I'd like to extrude each colored piece out by 5mm and create a 1.5mm shell out of it. I then will create a piece that will snap into each 5mm shell piece.
The trouble I'm encountering is when I have two shells next to each other it won't create a complete inside shell out of the sketch, and will instead overlap with neighboring extrusions.
Attached is the problem I'm running into along with a simple example of the kind of puzzle I'm talking about (an Abraham Lincoln puzzle, two pieces).
Any help is much appreciated.
