Adding fillets de-references rectangle dimensions
siriusphil
Message 1 of 18
siriusphil
I'm nearing the end of a complex (for me) design and needed to go back to an early rectangle sketch to add fillets.  When I do, the rectangle's location and size, which were dimensioned to the corners are now dimensioning nothing but each other.  Those two dimensions are referenced in many places later in the design so I get a warning when I try to delete them to recreate them referenced to existing points on the rectangle.  How do I re-reference the dimensions without losing the references?
BeforeBeforeAfterAfter
Replies (17)
Message 2 of 18
g-andresen
please share the f3d file for investigation
günther
Message 3 of 18
siriusphil
Here's the file.
Message 4 of 18
TrippyLighting
No file was attached to your post!
Message 5 of 18
siriusphil
I thought it was attached  last time.  Here it is again
Message 6 of 18
TrippyLighting
If you are trying to attach a model to post using an email reply, that does not work.
You'll have to use the web interface.
In other words, there still is no attachment 😉
Message 7 of 18
g-andresen
try again
günther
Message 8 of 18
siriusphil
You can see from the images I sent in my first post that the two dimensions on the right are referenced to the top right corner of the rectangle. Then I add the two fillets and the dimensions are no longer referencing the top of the rectangle because the corner has gone away. I just need to re-reference them to the point where the top of the rectangle is tangent to the fillet without deleting them and re-dimensioning, losing the references to those two dimensions later in the design.
Message 9 of 18
siriusphil
I was using the web interface and the attachment is there on my end when I drag and drop it.
Message 10 of 18
TrippyLighting
I don't usually put fillets in sketches if I can use 3D features to create fillets 😉
Message 11 of 18
jeff_strater
no, there is no way to re-reference a sketch dimension.  And yes, sketch fillet can be destructive to dimensions, as you observed, especially if you dimension to line endpoints. If you dimension to the line itself, instead, the dimension should survive.  Here is a simple example:
Jeff Strater
Engineering Director
Message 12 of 18
HughesTooling
@siriusphil  I can't get this to fail but looking at the image in post #1 I think you have show points unchecked. If you enable it you should see points at the ends of the dimensions, you can then add a coincident constraint between the lines and the points. Just select the coincident constraint then click the line (not the end point) then click the point at the end of the dimension.
Mark Hughes
Owner, Hughes Tooling
Message 13 of 18
siriusphil
Thanks Mark, that works.
Message 14 of 18
Julie_7
I was going to submit a feature request and then I saw this.
I think that when a rectangle is created, the dimensions entered should be set as the distance between the sides instead of the length of the side. This is still a properly dimensioned rectangle. However, it allows additional operations, such as corner fillets, to work without breaking/removing the rectangle dimensions.
Message 15 of 18
Julie_7
Putting the fillet in the sketch has the benefit of being able to see the dimension later without having to edit the feature. I can just show dimensions on a sketch. As far as I know, there is no way to show dimensions on a 3D body, although I would find it useful.
I often have to resort to using the inspect tool or edit the feature to remind myself what the dimensions are.
Message 16 of 18
TrippyLighting
Understood!
After over 30 years of professional CAD experience in Machine and Product design (20+ in Solid Works, 4+ in Alibre Design, 5+ in ZW3D, and almost 10 in Fusion 360. I won't mention AutoCAD ) I stand by what I said! Fillets and Chamfers do not belong into sketches, unless needed, e.g., for a sweep path..
Message 17 of 18
Julie_7
I agree with you. It is better to add fillets and chamfers to the body.
If I think about it from a manual machining point of view, the body will get turned into a blueprint that will be used to machine each part. The blueprint will show all of the dimensions, both from the sketch and from the final body.
I have only been using CAD for a couple years, initially to produce blueprints for my personal machining work, and, but mostly for the last year to produce 3D printed objects. Because I no longer produce the blueprints, I often want to look at the CAD design to see the dimensions. I guess what I really would like it a way to "show dimensions" for a body that works similar to "show dimensions" for a sketch.
This is just my 2 cents, based on a novice and non-professional point of view.
Message 18 of 18
TrippyLighting
@Julie_7 wrote:
... I guess what I really would like it a way to "show dimensions" for a body that works similar to "show dimensions" for a sketch.
That is possible in other CAD applications, just not yet in Fusion 360.
