1/2" 8TPI UNC Thread
Hi
Trying to make a Threaded knob for a wooden clock to match a threaded spacer cut using a hand tap.
Does Fusion have a 1/2" 8TPI thread in its data base?
Might have posted this question in wrong place, first time I asked for help!
Tim
mohammed.aliTDPXK
Hello @Anonymous ,
Are you looking for a threaded bolt/nut? You can get that using Insert-->Insert McMaster-Carr components--> search for the required component you need.
Let me know if this helps. Hit like button and Accept solution if this answers your query.
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
jhackney1972
As @mohammed.aliTDPXK said, you can go to McMaster-Carr insert command and pick up a piece of 1/2-8 threaded rod and then use it to create your tapped component by using the Combine command.  I believe that 1/2-8 thread is not a classification of of UNC thread, it is a ACME lead screw form.  Mode is attached with a section of 1/2-8 threaded rod and a block tapped using it, just make the threaded rod invisible.
John Hackney, Retired
