Bug Report: Fusion 360 Post Processor Issues with G68.2 Tilted Work Plane for HNC-848Di Control
Hello Autodesk Team,
I am reporting critical issues with Fusion 360 post processor when using G68.2 (Tilted Work Plane) for 3+2 multi-axis machining on HNC-848Di CNC control.
**Machine:** IRON MAC IMU-5X 400 PRO (5-axis machining center)
**CNC Control:** Huazhong HNC-848Di
**Post Processor:** rs274 multi-axis.cps (Generic RS-274D Multi-axis)
**Fusion 360 Version:** 2026 (current)
## Problems
1. **Drilling cycles (G81/G83) are expanded to linear moves (G0/G1)** at the CAM level before post processor is called. The `onCyclePoint()` function is never called, preventing the post processor from outputting drilling cycles.
2. **Incorrect command sequence:**
   - G69 (cancel tilted plane) outputs BEFORE the operation instead of AFTER
   - G43.4 (TCP) outputs AFTER G69 instead of BEFORE G68.2
   - G53.1 outputs without feedrate (should include F3000 parameter)
   - Machine-specific commands are missing (M61 M63, M51 M53, G05.1 Q0 for HNC controls)
## Impact
Programs generated by Fusion 360 execute drilling operations in the wrong coordinate system, resulting in incorrect part geometry or potential machine crashes.
## Expected Sequence (per HNC-848Di requirements):
```gcode
M61 M63                           ← Unlock rotary axes
G0 A-90. C270.                    ← Position rotary axes
G43.4 H1                          ← Enable TCP BEFORE G68.2 ⚠️
G68.2 X0 Y0 Z0 I90. J90. K180.   ← Set tilted work plane
G53.1 F3000                       ← Turn machine (with feedrate) ⚠️
M51 M53                           ← Machine mode
G05.1 Q0                          ← High-speed mode
G0 X0. Y35.                       ← Approach point
G98 G81 Z64. R71. F20.            ← Drilling cycle ⚠️
G80                               ← Cancel cycle
G69                               ← Cancel plane AFTER operation ⚠️
G49                               ← Cancel TCP
## Actual Sequence (Fusion 360 output):
```gcode
G0 A-45. C15.                     ← Position rotary axes
M8                                ← Coolant on
G68.2 X0 Y0 Z0 I-165. J45. K180. ← Set tilted work plane
G53.1                             ← Turn machine (NO feedrate)
G0 X-0.001 Y35.753               ← Approach point
G69                               ← Cancel plane BEFORE operation
G43.4 H1                          ← Enable TCP AFTER G69
G0 X-30.287 Y113.027 Z66.452
G1 X-11.464 Y42.779 Z-6.274 F40  ← Linear moves instead of cycle
**Critical consequence:** The drilling operation executes in the base coordinate system instead of the tilted work plane, resulting in holes drilled in wrong locations and orientations.
## Comparison with SolidCAM
SolidCAM correctly generates the proper sequence with drilling cycles (G81/G83) in tilted work plane operations. This proves the correct sequence is technically feasible and industry-standard.
## Investigation
I added debug comments to the post processor to track function calls:
- `onCyclePoint()` is **never called** for drilling operations with G68.2
- `onLinear()` is **not called** for the expanded linear moves
- Fusion 360 outputs G0/G1 commands directly, bypassing post processor cycle handling
**Conclusion:** Drilling cycle expansion happens at the CAM level before post processor execution. The post processor cannot prevent this.
## Current Workaround
I created a custom HNC post processor with 500+ lines of modifications to fix the command sequence issues. However, I cannot fix the drilling cycle expansion problem as it happens before the post processor is called.
## Test Files Available
I have test files available for verification:
- `1001.nc` - Fusion 360 output with custom HNC post (correct sequence, but cycles still expanded)
- `1002.nc` - Fusion 360 output with standard post (incorrect sequence)
- `ST1.NC` - SolidCAM output (correct reference from working machine)
- `rs274 multi-axis HNC.cps` - Custom post processor with all fixes
I can provide these files and detailed bug report document upon request.
## Request
Please prioritize this bug fix as it affects **multi-axis drilling operations**, a core CAM functionality. The current behavior makes Fusion 360 unsuitable for production use with HNC-848Di and similar controls without extensive post processor customization.
**Affected users:**
- Users with HNC CNC controls (Huazhong HNC-848Di and similar)
- Users with Fanuc controls requiring strict G68.2 sequence
- Users requiring drilling cycles in 3+2 operations (aerospace, mold making, die making)
- Users migrating from SolidCAM, Mastercam, PowerMill to Fusion 360
## Contact
I am available for:
- Providing test files
- Testing beta fixes on IRON MAC IMU-5X 400 PRO machine
- Sharing custom post processor code
- Video demonstration of the issue
- Remote session to demonstrate on actual machine
Thank you for your attention to this critical issue.
Best regards
