Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Select All - Users & Workers
Ref: https://forums.autodesk.com/t5/fusion-operations-ideas/document-management-amp-quality-policies/idi-...
As a workaround, it would be helpful to have a select all option for users and workers to enable or disable. This way you can target who gets the notification for reviewing the documentation.
You can then activate the document with just the selected few that it may effect.
If you have a small team then this probably doesn't effect you.
3 Comments
andrade_david
Hello @scott_greenway , would this "select all" be only under the scope of customizing who would view the quality policies?
Outside this context I don't find the "select all" option as a relevant option in the system for workers and users. Let me know if you disagree.
scott_greenway
Hi @dab yes that's correct. If we can target who the policies go to then the select all option as no real use.
andrade_david
Status changed to: Archived
Thanks! I'll mark this as archived, so we'd consider the possibility to detail which users and workers see the quality policies in the original idea.
