Files Hide/Show Tab
Files Hide/Show Tab
Please could the mobile icon be more obvious when its selected. It is very easy to mistake weather its selected or not.
5 Comments
scott_greenway
In addiction to this, it would be helpful to have the option to select Hide or Show when you've dragged and dropped. This would save you having to go back into the product again and select it.
jimmya333
We frequently encounter this issue as well. I believe there could be a larger button where the phone that clearly indicates options such as "Activate" or "File View.
andrade_david
Status changed to: Gathering Support
Hi @scott_greenway ,
Indeed, you're not the first one mentioning the icons may lead to mistakes, so thank you for posting this idea.
On a side note, since only PDF and images can be seen on the tablet, another possible area for improvement is not allow all files to be active on the tablets.
mmesser
Related to these previous comments, it would be nice if there was a user setting to choose whether all files are visible or not visible by default, when added to a production order.
andrade_david
Thank you for your comment, @mmesser. Not only to a production order, but also generic to all other entities, such as products and machines.
