Fusion Manufacture
Z limit warning Eureka
1 REPLY 1
Bnuno608
145 Views, 1 Reply
Im starting to use eureka, not plugin yet (allready exist)
We use a lot eureka but from powermill
 I running two parts, in machine dmg Evo 80 Linear,
Each NC is warning me in eureka with z limis, how can i Change this?
 In powermill i just have to mess with heigths on connections.
In Fusion i tried to lower the toolpath, but seems that the machines makes a movement to reach a diferent position
Cant understand if is something with Fusion or eureka.
Any ideias were to start looking?
1 REPLY 1
a.laasW8M6T
in reply to: Bnuno608
Hi
It is possible that the home positions set in the Machine Definition in Fusion are different to the ones you have in your machine  in Eureka.
Being that the machine is Heidenhain controlled the home position will be based off the Linear scale position which is often a non zero number, my mill for instance has a Z home pos of -66.327mm on the scale
Technology Administrators
