Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Z limit warning Eureka
1 REPLY 1
nubrandao
178 Views, 1 Reply
Im starting to use eureka, not plugin yet (allready exist)
We use a lot eureka but from powermill
 I running two parts, in machine dmg Evo 80 Linear,
Each NC is warning me in eureka with z limis, how can i Change this?
 In powermill i just have to mess with heigths on connections.
In Fusion i tried to lower the toolpath, but seems that the machines makes a movement to reach a diferent position
Cant understand if is something with Fusion or eureka.
Any ideias were to start looking?
1 REPLY 1
a.laasW8M6T
in reply to: nubrandao
Hi
It is possible that the home positions set in the Machine Definition in Fusion are different to the ones you have in your machine  in Eureka.
Being that the machine is Heidenhain controlled the home position will be based off the Linear scale position which is often a non zero number, my mill for instance has a Z home pos of -66.327mm on the scale
