Fusion Manufacture
using side of cutter in 4th axis machining
26 REPLIES 26
Message 1 of 27
customerserviceG2E9S
1682 Views, 26 Replies
I am trying to figure out how to machine spiral flutes on a cylinder using the side of the cutter instead of the end.  Anyone know how to do this?Photo Apr 27, 12 17 51 AM.jpg
26 REPLIES 26
Message 21 of 27
One more note, my model has concave surfaces because I only connected 2 squares, one on each end, so Y axis moves are result of that, otherwise you would see XZC moves for mill-turn or XZA moves for mill, excluding lead in and lead out moves.
Message 22 of 27
I'm going to play around with your model a little more later tonight and see if I can make it work for my application.  I will run a test on the mill later today also.  Thanks for your help!
Message 23 of 27
in reply to: customerserviceG2E9S
Second look at your file, your mill-turn setup has axis pointing in wrong direction. Here is my file with setup for mill-turn and mill, ignore Y axis moves in resulting code other then lead in/out moves, I don't care to redo the model.
One thing I do routinely is coordinate position of origin in both Model and Manufacture space for mill-turn work.
They are functionally independent but when I have need to add sketches and create additional planes or rotate features, it makes it simple to switch between work spaces and have things in sink afterwards.
Message 24 of 27
Can you still get this to work now that it is out of Bata. Every time I try to get the swarf to only do a 4th axis move it fails. Even duplicating your setup and just changing tools does not post. However if I just try your setup it posts just fine.
Thanks for any help.
Message 25 of 27
sales36ZAW
@Anonymous
Are you still able to do this process as described. We could generate this tool path a few months ago but since a fusion update the tool path generation fails
Message 26 of 27
in reply to: sales36ZAW
Yes mine fails every time I attempt to update the path in any way. I hope the Fusion team figures this out soon.
Message 27 of 27
seth.madore
The 4-axis limit for Swarf was removed. There were some significant bugs tied with it, and rather than try to fix them, the devs opted to remove the option and get to work on bringing in a better option for 4 axis controls. It will be some time though before those become available to the public.
Seth Madore
