Hey!
I was simply trying to use the 4th axis to turn a rectangular block to face 2 or 4 sides, and pocket 2 sides. When posting, it simply fails. Not sure if Ill be able to do what I would like all in one, if not I am also fine writing it in (just knowing how correctly) or lastly manually rotating the block once each individual operation is done. Thank you for your time.
(Looking through the forums, it looks like I may need to enable "machine configuration", as in through mach3mill.cps, the code itself?)
A post where I am wondering if the attached M4x.cps file is something I can use, going to check it out:
http://forums.autodesk.com/t5/post-processors/need-help-modifying-mach3mill-post-for-use-with-trunni...
-Yannick
Attached file and this is part of what comes up after posting.
Post processor signature could not be verified (error 0xfffffffc).
Generated by: Fusion 360 CAM 2.0.2271
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Tool orientation is not supported.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Thursday, August 04, 2016 8:00:31 AM
Post processing failed.
Solved by daniel_lyall. Go to Solution.
You have it along the Y axis not the X axis and you have not set the WCS.
There is a error in the file when you simulate the file it looks like there is a chunk being eaten by your tool holder, it is because you moved the model, I have had it my self it is not really there but just be aware.
Again, thank you so much. That posts fine for me now.
What a stupid error on my part - sometimes the most basic things are the easiest to overlook. A case of looking at the trees, not the forest, so to speak.
