Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
Using 4th Axis with Fusion 360 & Mach3
21 REPLIES 21
Message 1 of 22
10103 Views, 21 Replies
Hey!
I was simply trying to use the 4th axis to turn a rectangular block to face 2 or 4 sides, and pocket 2 sides. When posting, it simply fails. Not sure if Ill be able to do what I would like all in one, if not I am also fine writing it in (just knowing how correctly) or lastly manually rotating the block once each individual operation is done. Thank you for your time.
(Looking through the forums, it looks like I may need to enable "machine configuration", as in through mach3mill.cps, the code itself?)
A post where I am wondering if the attached M4x.cps file is something I can use, going to check it out:
http://forums.autodesk.com/t5/post-processors/need-help-modifying-mach3mill-post-for-use-with-trunni...
-Yannick
Attached file and this is part of what comes up after posting.
Post processor signature could not be verified (error 0xfffffffc).
Generated by: Fusion 360 CAM 2.0.2271
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Tool orientation is not supported.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Thursday, August 04, 2016 8:00:31 AM
Post processing failed.
Tags (4)
21 REPLIES 21
Message 21 of 22
daniel_lyall
in reply to: hhshermit
You have it along the Y axis not the X axis and you have not set the WCS.
There is a error in the file when you simulate the file it looks like there is a chunk being eaten by your tool holder, it is because you moved the model, I have had it my self it is not really there but just be aware.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 22 of 22
hhshermit
in reply to: daniel_lyall
Again, thank you so much. That posts fine for me now.
What a stupid error on my part - sometimes the most basic things are the easiest to overlook.  A case of looking at the trees, not the forest, so to speak.
