I prefer to name the nests after using the nesting plugin to help distinguish between them. I usually use the type of sheet good. I also sometimes will go through and rename the sheets as the number continues to climb higher and higher with each nesting. I have noticed that if I create labels, upon completion of them being generated, the standard nest and sheet names come back. Please take a look and consider fixing.
Cheers,
Matt
