Fusion Manufacture
Use the thread whirler correctly as a tool
4 REPLIES 4
Frank_24
257 Views, 4 Replies
Hello everyone.
I often use Sorotec thread whirlers for producing various internal and external threads.
That works well.
However, I have not yet managed to create the tool in the Fusion library so that there are no collisions in the simulation.
This is probably because I cannot represent the actual cutting edge and shaft geometry in the tool library.
My question:
Can I create my own tool shapes and if so, how does it work?
L.G.
Frank
4 REPLIES 4
programming2C78B
in reply to: Frank_24
In english they are called threadmills. Your shaft is defined much wider then it looks. You could just use a Form Mill that you sketch.
Please click "Accept Solution" if what I wrote solved your issue!
Frank_24
in reply to: programming2C78B
ok, I sketched a Form Mill..
And now?
regards
Frank
programming2C78B
  1. Draw a cross section outlining half of the tool.
  2. Exit the Design workspace with the sketch visible and switch to the Manufacture workspace.
  3. From the Milling tab, click Manage > Form Mill.
  4. Select the entire sketch as the profile.
  5. Set the tool axis to be a centerline on the tool's rotational axis.
  6. Choose the desired compensation point, then click OK. The compensation point is a vertex that follows along the toolpath.
  7. Open the Tool Library, and the new form tool will be listed under the current document.
Why does your tool have a 43* angle? Is this just for representation/test?
Frank_24
@programming2C78B:
That helped – thank you very much.
The drawing was initially only intended as a test and was not dimensioned.
The cutting angle is of course 60°
regards
Frank
