Hello everyone.
I often use Sorotec thread whirlers for producing various internal and external threads.
That works well.
However, I have not yet managed to create the tool in the Fusion library so that there are no collisions in the simulation.
This is probably because I cannot represent the actual cutting edge and shaft geometry in the tool library.
My question:
Can I create my own tool shapes and if so, how does it work?
L.G.
Frank
Solved by programming2C78B. Go to Solution.
In english they are called threadmills. Your shaft is defined much wider then it looks. You could just use a Form Mill that you sketch.
ok, I sketched a Form Mill..
And now?
regards
Frank
Why does your tool have a 43* angle? Is this just for representation/test?
That helped – thank you very much.
The drawing was initially only intended as a test and was not dimensioned.
The cutting angle is of course 60°
regards
Frank
