Unsupported geometry for 2D Open Pocket detection
tiktuk
tiktuk
I'm trying to make a simple pocket but I get the following error: "Unsupported geometry for 2D Open Pocket detection". I don't really understand why. It seems like a really simple case.
I have attached the part (copied from another file, that's the reason there's errors in the timeline).
Any ideas?
Replies (11)
engineguy
@tiktuk
Yes, I believe there are issues with the new system for 2D Pockets, either just select the edges for the open pocket or go to your "Preferences" and enable the Legacy 2D Pocket option as shown in the image below and it should then work OK for you 🙂
Joshua.Aigen
Hi @tiktuk, This is a known issue read about it HERE.
I would say you have two options delete these small radius corners.
Or second option is to machine all the way around the part by selecting the top surface and setting the height to a selection and picking the face you would like to machine to (heights tab).Forum.JPG
Joshua Aigen
Workshop Supervisor
Joshua.Aigen
Found another option, I ran a 2d contour pass with 2 rough passes turned on, as you can see in the image it hooked around but does not contact the part.Forum2.JPG
Joshua Aigen
Workshop Supervisor
engineguy
@tiktuk
See images below, image one and use the Red arrows to control the pocket which gives you image two, see attached file  🙂
tiktuk
Thanks a lot, this worked, @engineguy 🙂 !
@Joshua.Aigen, thanks a lot for taking a look at it too!
changedsoul
Hi, Sorry to hijack this thread, but I just ran into the exact error and I tried enabling the legacy pocket feature, but still no go.
Here is the link to the file: https://a360.co/3mkink9
I was able to clear out the area by doing single contour with multiple offsets, selecting a single side of each post sticking up, but this was tedious. A better way would have been to get this to work by just selecting the whole bottom face like I have in the file.
Is there a trick to this?
tiktuk
You can also try the 3d strategy "Flat". I saw it mentioned in another, similar thread. Seemed to work for my problem too.
But strange that it's so difficult to make simple pockets, suddenly.
changedsoul
@tiktuk
Hey, thanks for that tip. Thats actually pretty close to what I ended up doing manually. This would have been so much easier using the FLAT 3d pattern in the first place lol.
tiktuk
Yeah, I was also pretty stoked when I discovered it, very useful 🙂 !
engineguy
@changedsoul
OK, it is all about selection/selection/selection !!
Yes, we all know that the 2D stuff can be a bit tiresome, it will no doubt be made easier at sometime but it can be used fairly easily now 🙂
The file that you uploaded I was able to easily select and toolpath the 2D Adaptive Pocket and a straight 2D Pocket, see image below, attached modified file and a Screencast showing the approach/method I used to get it done, just different not a "workaround"  🙂 🙂 🙂
Screencast link:- https://autode.sk/3FdUlyD
BTW It is much better to attach a Fusion file by going to :-
File > Export > Select f3d format > Save to a location on your computer > Then attach it to your reply.
rudi.scholtenZWZ8M
Hi, you made my day. I did not think about the 3D flat. i was strugeling for 2 Days with the 2D pocket. normally worked well for me, but not this time, 3D flat works SPER. thank you.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
