Turning Tips Not to Scale in Tool Library
mattdlr89
mattdlr89
I'm new to the turning side of Fusion so I am just getting my head around how to define all the tools.
I was getting a bit confused as I couldn't get them to look like they do in real life and I think this is because the tips are not drawn to scale in relation to the holder.
I scaled the window until the squares where the right size and the tip as drawn on the screen is way off!
Screenshot below shows that the tip pokes out the back of the holder it doesn't look anything like this on the lathe - so I was getting confused that I may have not defined it correctly. I then held up the tip to the screen and you can see the difference in the picture below.
@christopher.cooperVHK2N tagging you as you seem to be the tool library contact!
Furthermore the lathe side of tooling seems a bit basic, are there plans to be able to select different tip edges. For example any grooving or part off tool can be easily defined from either side of the tip. Fusion doesn't allow me to select which side - typically all our programs are currently set up the edge that Fusion can't cope with. Screenshot below I'd like to select the corner where the red arrow is
Replies (8)
@mattdlr89 Thanks for the feedback. We are aware of a bug related to the turning insert size and we will be looking to get to it very soon - Ref CAM-25330.
As for turning tool improvements they have certainly been discussed in depth and I will make sure the selection of alternative tip edges are considered.
Christopher Cooper
Technical Consultant
mattdlr89
Great, I hope the alternative tip edges get added soon - if we were starting fresh it wouldn't really matter but we have lots of programs that use the opposite side so I'd like to continue with that set up.
Is much work being done on the lathe aspect of the tool library? It looks a little light in places. Such as the cutting data tab could be have a lot more variables for ease of use, like depth of cut, limiting spindle speed etc.
akash.kamoolkar
@mattdlr89 I've made tickets for adding max spindle speed and depth of cut to the turning tool cutting data.
Akash Kamoolkar
Akash Kamoolkar
Software Development Manager
mattdlr89
@akash.kamoolkar
Great. It also seems to me that when defining a boring bar in the tool library it should also have an option for the clearance diameter (Under radii in the toolpath box).
Every boring bar will have a minimum diameter it can be used for so it would make sense to capture this information at a tool level and automatically populate the toolpath field.
Sq_14
Hi, you might as well add a field to define the tool as 'over head mounted'.
This should force the program to simply flip the X-axis in tool path generation within the operation. In other words, when there's a generated code like
G00 Z10.0 X10.0
G01 Z5.0  X5,0
generated with standard tool setup
with the  'over head mounted' checkbox checked it generates this
G00 Z10.0 X-10.0
G01 Z5.0  X-5,0
The tool path and all will be the same, except, after the path is generated and before its displayed, it runs through a  subroutine which multiplies the x-numbers by (-1). Whalla, perfect toolpath for negative x-values on a lathe with upside mounted tools. Not sure what happens to G2/G3 arc values, because they may or may not to be inverted or not, programing these arcs are not my strong suit, but i'm sure you guys in the know can 'easily' figured this out.
Sq_14
addenum:
you also might consider looking into the definitions of lathe tools of the manufacturers.
For a boring bar they always give you an f-value. This shows how much the tipp of the insert is away from the center line of a tool. Fusion shows this value as cutting width, but in fact, cutting width is another animal.
Why not stick to already established naming convention and conventions, makes things a whole lotta easier to grasp.
mattdlr89
@Sq_14
Yeah I found the boring bar geometry definition a bit odd. Having to rework all the values from the manufacture to input it correctly. +1 to the above suggestion!
Also I've mentioned it before but you can buy solid boring bars (i.e. without tips) it would be nice if there was a better way to define without fusion forcing you to select a turning tip.
Sq_14
I didn't check, but for such a case, creating a form tool just like in the milling section comes to my mind.
Don't know if that's working in turning, but that's what i would expect to handle such a situation.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
