is there a way to extend a turning tool path beyond the part (to allow a parting surface) with "allow grooving" still on, but without it digging in at the rear? (first picture shows what i have, so obviously i need "grooving" so it gets the feature in the middle of the part, but i want the extension off the rear of the part to just be flat in line with the OD
Solved by paul.clauss. Go to Solution.
Hi @HAMMENG
Thanks for posting! I wanted to jump in to show you how I would use sketch geometry and an open contour toolpath to approach this problem. I have illustrated this in the screencast below:
