Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
turning beyond part
4 REPLIES 4
HAMMENG
289 Views, 4 Replies
turning beyond part
is there a way to extend a turning tool path beyond the part (to allow a parting surface) with "allow grooving" still on, but without it digging in at the rear? (first picture shows what i have, so obviously i need "grooving" so it gets the feature in the middle of the part, but i want the extension off the rear of the part to just be flat in line with the OD
4 REPLIES 4
Steinwerks
in reply to: HAMMENG
I would limit the toolpath top the back end of the part and create a second one without grooving that extends beyond the back with Rest Machining enabled. If you limit the homing behavior it should act very closely to a single toolpath.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
HAMMENG
in reply to: Steinwerks
Seems a bit of a clunky solution. There will be wasted rapid time between
the 2 tool paths. Sure it wouldn't be much and i am only making 100 of
these, but time is money as they say.
paul.clauss
Hi @HAMMENG
Thanks for posting! I wanted to jump in to show you how I would use sketch geometry and an open contour toolpath to approach this problem. I have illustrated this in the screencast below:
Hopefully this helps! Please let me know if you have any other questions.
Paul Clauss
Product Support Specialist
HAMMENG
Perfect Paul.
I didn't even think to use that feature (this is the first turned part I've programmed in fusion... And the first part I've made on my fanuc controlled machine, previously just used mazatrol on my mazak lathe)
I ended up just editing the code, but obviously this is more elegant of a solution.
Here was the result (single stepped with reduced feeds so finish isn't great)
https://goo.gl/photos/CYxQd87qB7vTw41T8
Technology Administrators
